How to copy a field (column) values to paste in another field in the same Attribute table in ArcGis Pro
2333
06-21-2022 10:10 AM
HadiK
I need to copy a field values to another field the same attribute table,
Its not the that I want to joint, I just need to copy the values from a field that I have jointed from an excel file to a new field.
Tags (1)
JohannesLindner
Just the part after the equals sign.
Have a great day!
Johannes
DanPatterson
MVP Esteemed Contributor
Use the field calculator.  Assuming you have added a field of the appropriate type
python parser
!YourOtherField!
note the ! marks surrounding your other fields name
... sort of retired...
HadiK
Thank you for your response
I have tried like this:
!NewField!=!MyField!
Is that correct?
Cause I got error in terms on Null values!?
JohannesLindner
Have a great day!
Johannes
