I need to copy a field values to another field the same attribute table,
Its not the that I want to joint, I just need to copy the values from a field that I have jointed from an excel file to a new field.
Just the part after the equals sign.
Use the field calculator. Assuming you have added a field of the appropriate type
python parser
!YourOtherField!
note the ! marks surrounding your other fields name
Thank you for your response
I have tried like this:
!NewField!=!MyField!
Is that correct?
Cause I got error in terms on Null values!?
