How can I return a layer name to a specific field using Field Calculator?
1158
07-30-2022 02:35 AM
KhamisBaroud
I want to return the layer name to a specific field using Field Calculator, is there a Python code for that?
Thanks in advance
Tags (3)
DanPatterson
MVP Esteemed Contributor
In the "field calculator" no.
But, if you want to fully script something then you can use
Calculate Field (Data Management)—ArcGIS Pro | Documentation
see the code examples for some ideas
... sort of retired...
