Publish fails with message "request requires http authentication ()"
2660
11-24-2010 06:06 PM
runegullstrom
Hi All,
I'm experimenting with geoportal v10. So far, all's good. I'm able to login, add some meta data, search for it, I can see the record in the db tables..
Next step is to publish metadata attached to an SDE feature class.
I use the Publish Metadata tool in ArcCatalog. When I look in the logfile I see
http status 401 -
type status report
description: this request requires http authentication()
What could be the cause?
regards,
Rune
