Datasets with null bbox are shown in JSON as [-180,180,-90,90]
3854
07-17-2013 12:09 AM
StephenLead
Honored Contributor
Hi guys,
In instances where a dataset has no bounding box, the GeoPortal doesn't show the Zoom To option in the Search results:
[ATTACH=CONFIG]25995[/ATTACH]
However, the JSON output for these dataset shows a bounding box covering the whole globe:
"bbox" : [-180.0, -90.0, 180.0, 90.0],
Is this a bug? IMO the bbox should be null if it doesn't exist for the data. Any workarounds you can suggest?
Steve
GeoPortal Genie | a modern front-end to Esri GeoPortal Server
MartenHogeweg
it is definitely 'by design'. see com.esri.gpt.control.georss getValidMinX-like methods. perhaps something to change. there is not such a thing as a 'null geometry' from what I can see on GeoRSS, so better would be to omit the entire georss:polygon element when there is no geometry in a record.
if this happens with ArcGIS items, check the ags-toDC.xslt as there is a default extent assigned there upon publishing.
