NEED HELP TO DESIGN CONNECTION AT THE GRID SUBSTATION -TIERS AT THE ELECTRICAL DOMAIN
1309
07-05-2023 12:34 AM
RomuldKiobya
Look attached document for more understanding. I have an incoming HV line Mufindi grid substation to the Mbeya Grid substation (Transmission tier). HV signal/connection travel to HV transformer (220KV/33KV) at the terminal of XFR-High. I created a Sub-transmission tier at the XFR-Low that ends with an MV circuit breaker at the Bus terminal. I made a Distribution tier at the MV Circuit breaker at the CB Line terminal.
My doubt about the Sub-transmission tier. And at what condition sub-transmission tier is used?
JohnAlsup
In this case you would not need the subtransmission tier.  Subtranmission is just like transmission, just a lower voltage, so subtransmission runs between stations, just like transmission.  I think you are trying to build a tier inside the substation for the equipment between the transformer and the breakers, is that correct?
John Alsup
jalsup@esri.com
RomuldKiobya
Yes, I need to create subnetwork controller and subnetwork, starting Low terminal  of HV transformer to CB bus of MV Circuit Breaker. So which tier I suppose select if not sub-transmission (contain high voltage devices and MV devices)  at sub network definition tool?
JohnAlsup
Then you would just make the HV to MV transformer a subnetwork controller in the Distribution tier, call it Sub1 or some other name, and keep you the other subnetwork controllers at the circuit breakers in the distribution tier.
John Alsup
jalsup@esri.com
