Is Arcgis pro support fileGDB for UNMODEL in latest version
2792
13
07-14-2020 11:44 PM
SrinivasaRao1
Hi ,
Is any body could update if UN model is not required for Server & Portal enterprise to proceed. Please suggest and let us know.
We are trying to explore on UN model for last few months and we are not able to proceed due to server related issues in our organization.
Is there any way to proceed without having any enterprise related servers which can be locally used as filegdb to continue on UN modelling for Electric.
SrinivasaRao1
where will be the tool documentation, please let us know
MikeMillerGIS
Esri Frequent Contributor
Are you applying that to a gdb with an UN already in it? If so, we have no control terminal IDs, and the electric domain terminals are added after existing terminals so the IDs will be off causing the import of controllers to fail.
SrinivasaRao1
We are creating UN model in FGDB in the local machine as this is available in 2.6 versions.
The further analysis we should remove data in c_subnetworkcontrollers table which was stored from the UN Model template
I Will let you know the result once it is done.
SrinivasaRao1
We are able to close all the errors and now local gdb (staging gdb) was cleaned without any topology errors. Please let us know from where do we need to have sde database or we can directly publish to the portal, your support is appreciated.
