Is Arcgis pro support fileGDB for UNMODEL in latest version
2768
13
07-14-2020 11:44 PM
SrinivasaRao1
Hi ,
Is any body could update if UN model is not required for Server & Portal enterprise to proceed. Please suggest and let us know.
We are trying to explore on UN model for last few months and we are not able to proceed due to server related issues in our organization.
Is there any way to proceed without having any enterprise related servers which can be locally used as filegdb to continue on UN modelling for Electric.
This widget could not be displayed.
MikeMillerGIS
Esri Frequent Contributor
The utility network is supported in the File Geodatabase as of 2.5. You can use the Asset Package to File Geodatabase tool to create one from any asset package or manually create one using the utility network tools.
https://solutions.arcgis.com/shared/help/data-loading/get-started/install-the-data-loading-tools.htm
MikeMillerGIS
SrinivasaRao1
Thanks for update and let us know, we will come back if any.
SrinivasaRao1
We have tried using that link and that link contains python script to update asset package and error was thrown when run on geodatabase. Also our query is that for UN modelling Electric or Warter , do we required enterprise portal system and DB to be there or we can do only in FGDB for UN related activities till tracing. Please let us know.
in <module>
arcpy.pt.StageUtilityNetwork(
AttributeError: module 'arcpy' has no attribute 'pt'
MikeMillerGIS
Did you follow the instructions on install the toolset?
SrinivasaRao1
Yes, I followed.
Regards
Srini
SrinivasaRao1
Hi, Any further update, could not able to proceed further on this. Please let us know, is it really possible to do in file geodatabase to apply the asset package without the DB & Server portal.
SrinivasaRao1
Hi All,
Is there any solution to remove the below error during the process of updating the asset package to FGDB.
SrinivasaRao1
Please let us know how we can fix this issue, if the feature can be deleted is the issue resolved
