Is arc pro linked to a specific version of the utility network?
1825
07-09-2019 06:25 PM
DamienPyne
We have recently built a PoC environment of pro2.4/10.7.1/UN v3.1, yet still have a pro2.3/10.6.1/v2.0.1 environment available.
After ensuring I am pointed to the correct portal, I have tried to open one of the pro2.3/v2.0.1 project files on pro 2.4 and cannot see the details of the Utility Network properties, and therefore UN functions fail. (ie validate topology states the service is not enabled)
The dark theme is viewing on pro 2.4, while the light theme is pro 2.3 for the same map and portal, etc.  The same issue occurred when adding the raw v2.3 service to a new map in pro 2.4.
is there a compatibility link between pro2.4 and UN v3; and pro2.3 and UN v2?
by Anonymous User
Not applicable
Hi Damien,
Utility network is dependent on a particular version of ArcGIS Pro and ArcGIS Enterprise. Utility Network Compatibility
Have a look at the link below and let me know if there is a followup question.
https://pro.arcgis.com/en/pro-app/help/data/utility-network/utility-network-dataset-administration.h...
Cheers,
Rushi
by Anonymous User
Not applicable
Hi Damien,
Cheers,
Rushi
DamienPyne
Thanks Rushi.  This is still not clear.  As you mentioned and indicated in the table there appears to be a version dependency, yet the dot points above the table are contradictory.
