00396: The dataset version is later than is supported by your server. Minimum version
2113
11
08-09-2025 07:23 AM
RomuldKiobya
Review the attached photo. I wanted to publish feature layers as a web map in ArcGIS Online.  IError by version.jpg
RomuldKiobya
It is not my fault, It is Esri. Not all people can afford Enterprises subscription. We use AGOL to connect with  Field Map  (enables data collection). After that, I  migrate GDB  from AGOL to GDB on ArcGIS Pro 3.5 to continue with the processing of UN Validation and other QA & QC issues.
RossStrachan3
Hi Romuld,
I don't think anyone is pointing blame here not to you nor to Esri - just trying to work out how to help to solve your interesting problem.
If I understood your workflow:
1. You manage your UN in a FGDB (or mobiled GDB) in single-user mode i.e. no Branch Versioning, no ArcGIS Enterprise.
2. Periodically you publish it to AGOL for use with Field Maps.
3. Periodically you extract and consolodate the Field Maps updates into your local UN using Pro.
You used to use Pro 2.9 now you are using 3.5.
I was suspecting the new 64bit objectid type might be causing your issue but I have just published a webmap to AGOL with an empty UN that has 64bit objectids (using Pro 3.3.5).
If you have made sure everything is compatable perhaps raisng a support case is your best option now.
Best
