One of the most powerful features in Esri’s 3D viewers, like Scene and MapMaker is the Daylight tool – at least in my opinion. The Daylight tool creates a light source (sun) on the map and results in accurate lighting levels for the selected date and time. You can use the play button to cycle through the lighting levels by time or date. For example, here’s the Grand Canyon at about 7 am on March 15, 1952.
You can move beyond ambient lighting and generate accurate shadows of topography and 3D objects, like buildings.
Here to, you can set shadows to generate for a specific time and date. You can also use the play buttons to loop the shadow render by date or time. See the shadow of the Space Needle in Seattle at about noon during the 1995 Winter Solstice.
For a little extra credit, if you want to capture movement of shadows across an entire and present it in a short enough span of time to keep student attention, you can do a few screen recordings on your computer and stitch together in a video editor – and you’ll get something like this.
To learn more about the Daylight tool, see:
Teachers, looking for the Next Generation science standards connections?
Kindergarten standard: K-PS3-1
Grade 1 standard: 1-ESS1-1
Grade 3 standard: 3-ESS2-1
Middle School standard: MS-ESS1-1
High School (grades 9-12)
Standard: HS-ESS1-1
Standard: HS-ESS1-4
Standard: HS-ESS2-4
Standard: HS-ESS2-2
