Hello everyone,
Anyone can share a source code in C# or VB.Net about how to connect to ArcGIs Server.
I have a code that was working in 10.0 but it does not work anymore.
Thank you.
Are you looking to interface with server through the web or through runtime SDK?
Runtime SDK.
Can you be more specific as to what you're trying to do? For instance, this page - Use a MapView to display a map—ArcGIS Runtime SDK for .NET | ArcGIS for Developers - describes how to display a map using the runtime SDK. If you notice, there are service URIs for tiled map services and also feature layers, e.g. http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Earthquakes/EarthquakesFromLastSevenDays/MapServer/0"/
That's a connection to ArcGIS Server...
I can't answer your question...but tagging ArcGIS Runtime SDK for .NET for more exposure.
I believe you have to do it through map services. After searching for a long time I found this
Supported geodatabase formats—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
which says
ArcGIS Runtime for .NET against Enterprise geodatabase -> Supported only if using services
I hope someone proves me wrong.
Hi Jose,
Depends on what you mean by connect I suppose. I put two samples below that should work. Once simply adding the ArcGIS Server layer to a current map view, and another querying against an ArcGIS Server layer.
//Add a new dynamic map service layer. Replace the URL with your desired ArcGIS Server rest URL.
//Use ArcGISTiledMapServiceLayer if it is a tile map service instead.
var layer = new ArcGISDynamicMapServiceLayer(new Uri("http://MyServer/arcgis/rest/services/MyService/MapServer"));
await layer.InitializeAsync();
//add the layer to the map and zoom to its extent
this.MyMapView.Map.Layers.Add(layer);
If by connect you mean you just want to query against the layer, then you'll want to use a QueryTask.
QueryTask myQueryTask = new QueryTask(new Uri("http://MyServer/arcgis/rest/services/MyService/MapServer/0"));
Query myQuery = new Query("OBJECTID < 100");
OrderByField myOrder = new OrderByField("OBJECTID", SortOrder.Ascending);
myQuery.OrderByFields.Add(myOrder);
myQuery.ReturnGeometry = true;
myQuery.OutFields.Add("OBJECTID");
myQuery.OutFields.Add("GLOBALID");
QueryResult myResult = await myQueryTask.ExecuteAsync(myQuery);
from 10.0 to 10.1 there was a huge change on how to access ArcGIS Server... Local connections (AGSConnection()) are no more... I am sure you have found that out.
As per others questions, it depends on what you are looking for.
It is through the REST/SOAP service API?
Is it to create SOIs or SOEs ? ( Server object interceptors / Server object extensions )
I just want to re-write this VB.Net code using ArcGIS Server 10.2. It works fine in ArcGIS Server 10.0 but it fails in ArcGIS Server 10.2:
Dim gputilities As IGPUtilities = New GPUtilitiesClass()
Dim myResult As Boolean = True
' Declare server context variables Dim mapServerContext As IServerContext = Nothing
Dim agsServerConnection As ESRI.ArcGIS.ADF.Connection.AGS.AGSServerConnection = Nothing
Dim featuresCount As Integer
Try
Dim username As String = ConfigurationManager.AppSettings("username") Dim password As String = ConfigurationManager.AppSettings("password") Dim domain As String = ConfigurationManager.AppSettings("domain") Dim hostname As String = ConfigurationManager.AppSettings("hostname") Dim mapservice As String = ConfigurationManager.AppSettings("mapservice")
' Connect to ArcGIS Server Dim adfIdentity As New ESRI.ArcGIS.ADF.Identity(username, password, domain) agsServerConnection = New ESRI.ArcGIS.ADF.Connection.AGS.AGSServerConnection(hostname, adfIdentity) agsServerConnection.Connect()
If (Not agsServerConnection.IsConnected) Then
agsServerConnection.Dispose() Return False
End If
' Get a reference to the server object manager to use in creating server objects Dim serverObjectManager As ESRI.ArcGIS.Server.IServerObjectManager = agsServerConnection.ServerObjectManager
' Create a server context for and get a reference to the BloomfieldTownship map service. We will ' use this to access map information and query features. mapServerContext = serverObjectManager.CreateServerContext(mapservice, "MapServer")
Dim mapServer As ESRI.ArcGIS.Carto.IMapServer2 = TryCast(mapServerContext.ServerObject, ESRI.ArcGIS.Carto.IMapServer2)
' Get a reference to the map service's server objects
Dim mapServerObjects As ESRI.ArcGIS.Carto.IMapServerObjects = CType(mapServer, ESRI.ArcGIS.Carto.IMapServerObjects)
Dim map As ESRI.ArcGIS.Carto.IMap = mapServerObjects.Map(mapServer.DefaultMapName)
