[RESOLVED] GDB in Oracle: Error calling SDE.St_GeomFromWKB from OCI
2589
10-03-2017 01:07 AM
DenisVitsko
-- The anonymous sql-block with St_GeomFromWKB is working good
DECLARE
    :GEOM BLOB;
BEGIN
:GEOM := HEXTORAW('010200000004000000b6f3fdd497961341c74b37097b2042418941606596961341819543bb822042416f1283c05f971341ac1c5a149d20424175931884829613410ad7a350b6204241');
UPDATE "SDE"."MYTABLE" SET "SHAPE" = SDE.ST_GeomFromWKB(:GEOM, 3405)
WHERE "OBJECTID" = 1;
END;
SELECT SDE.St_AsText(SHAPE) AS SHAPE FROM "SDE"."MYTABLE" WHERE "OBJECTID" = 1
This SQL is executed in Oracle SQL Developer with good result.
When my application called this function I'm got the error (using OCI):
ORA-03001: unimplemented feature
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 237
ORA-06512: at "SDE.ST_GEOMETRY_OPERATORS", line 162
The BLOB value which application send as WKB is properly.
I'm check it several methods:
- used it as parameter for constructor of SDO_GEOMETRY;
- add the blob field to the table and save BLOB in this field, then convert this value to St_Geometry.
The convertion from BLOB field with WKB value to the St_Geometry also propertly works in Oracle SQL Developer only.
UPDATE "SDE"."MYTABLE" SET "SHAPE" = SDE.ST_GeomFromWKB("SHAPE_BLOB", 3405) WHERE "OBJECT"=1;
The execution this command from my external application using OCI is finished with such error:
The message
is meaning that error while call the funlction geomfromshape() from library "st_shapelib.dll"
Some others functions from "st_shapelib.dll" are successful calling from my application using OCI.
For example the function SDE.ST_AsBinary which calling from OCI application is works properly.
Why SDE.St_GeomFromWKB not working when its calling from OCI application?
Thanks for any ideas!
PS. Additional information.
Oracle Database 11g Enterprise Edition Release 11.2.0.1.0 - 64bit Production
The library st_shapelib.dll is added to Oracle Database propertly.
SELECT * FROM USER_LIBRARIES;
return
ST_SHAPELIB | c:\app\panuser\product\11.2.0\dbhome_1\BIN\st_shapelib.dll | Y | VALID
Checking "invalid" objects
select object_name, object_type from user_objects where status = 'INVALID'
returns no records.
DenisVitsko
The library st_shapelib.dll does not allow to use your own transaction.
I was forced to remove from my OCI-programme this code snippet:
// Allocate Transaction Handle
OCIHandleAlloc((dvoid *)pOCIEnviron, (dvoid **)&pOCITrans, OCI_HTYPE_TRANS, 0, 0);
// detach the transaction
OCITransDetach(pOCISvcCtx, pOCIError, 0);
// Append transaction to service context
OCIAttrSet((dvoid *)pOCISvcCtx, OCI_HTYPE_SVCCTX, (dvoid *)pOCITrans, 0, OCI_ATTR_TRANS, pOCIError);
XID gxid;
// global transaction id = [1000, 123, 1]
gxid.formatID = 1000; // format id = 1000
gxid.gtrid_length = 3; // gtrid = 123
gxid.data[0] = 1;
gxid.data[1] = 2;
gxid.data[2] = 3;
gxid.bqual_length = 1; // bqual = 1
gxid.data[3] = 1;
OCIAttrSet((dvoid *)pOCITrans, OCI_HTYPE_TRANS, (dvoid *)&gxid, sizeof(XID), OCI_ATTR_XID, pOCIError);
OCIAttrSet ((dvoid *) pOCITrans, OCI_HTYPE_TRANS, (text *) MY_TRANSACTION_NAME, wcslen (MY_TRANSACTION_NAME), OCI_ATTR_TRANS_NAME, pOCIError);
// Start transaction with timeout 90 sec
OCITransStart(pOCISvcCtx, pOCIError, 90, OCI_TRANS_NEW);
After that function ST_GeomFromWKB has begun to work properly.
So, I concluded that when you using "st_shapelib.dll" library in your OCI-application you may use OCITransStart, OCITransCommit and OCITransRollback with default transaction only and can not make your own transaction. Otherwise some SDE functions such as St_GeomFromWKB will not work properly.
