Implement Icommand in VB.net
805
06-17-2023 09:35 PM
Suman_Kar
I want to implement Icommand in VB.net. After build the dll file when I try to load this dll file in Arcmap 10.8 then it shows that can't load type library from specified file. I have used below code for implement this dll file. Please help on this
Imports ESRI.ArcGIS.SystemUI
Public Class Class1
Implements ESRI.ArcGIS.SystemUI.ICommand
Public Sub OnCreate(Hook As Object) Implements ICommand.OnCreate
m_pApp = Hook
Throw New NotImplementedException()
End Sub
Public Sub OnClick() Implements ICommand.OnClick
Dim MyForm As New Form1
MyForm.Show()
End Sub
Public ReadOnly Property Enabled As Boolean Implements ICommand.Enabled
Get
Enabled = True
End Get
End Property
Public ReadOnly Property Checked As Boolean Implements ICommand.Checked
Get
End Get
End Property
Public ReadOnly Property Name As String Implements ICommand.Name
Get
Name = "Merge Geodatabase V2.0"
End Get
End Property
Public ReadOnly Property Caption As String Implements ICommand.Caption
Get
Caption = "Merge Geodatabase V2.0"
End Get
End Property
Public ReadOnly Property Tooltip As String Implements ICommand.Tooltip
Get
Tooltip = "Merge Geodatabase V2.0"
End Get
End Property
Public ReadOnly Property Message As String Implements ICommand.Message
Get
End Get
End Property
Public ReadOnly Property HelpFile As String Implements ICommand.HelpFile
Get
HelpFile = ""
HelpFile = "Merge.hlp"
End Get
End Property
Public ReadOnly Property HelpContextID As Integer Implements ICommand.HelpContextID
Get
HelpContextID = 10001
End Get
End Property
Public ReadOnly Property Bitmap As Integer Implements ICommand.Bitmap
Get
End Get
End Property
Public ReadOnly Property Category As String Implements ICommand.Category
Get
Category = "Land_Suman"
End Get
End Property
End Class
