I am attempting to autopopulate a MunicipalID field (long integer) with a number between 1-21 depending on the value selected in a domain based text field. My initial thought was an expression in the dynamic value table using the IIF function. The first attempt was too long being a total of 765 characters, no spaces. I then tried to break it down into smaller chunks and assign a rule weight so that I could still use the IIF function. No matter how I write it I cannot get the expression to work. I am hoping that someone can either tell me what I am doing wrong or tell me a different way to accomplish this. My initial statement was as follows:
IIF([Municipality]="Bethel",1,IIF([Municipality]="Callicoon",2,IIF([Municipality]="Cochecton",3,IIF([Municipality]="Delaware",4,IIF([Municipality]="Fallsburg",5,IIF([Municipality]="Forestburgh",6,IIF([Municipality]="Fremont",7,IIF([Municipality]="Highland",8,IIF([Municipality]="Liberty",9,IIF([Municipality]="Lumberland",10,IIF([Municipality]="Mamakating",11,IIF([Municipality]="Neversink",12,IIF([Municipality]="Rockland",13,IIF([Municipality]="Thompson",14,IIF([Municipality]="Tusten",15,IIF([Municipality]="Bloomingburg Village",16,IIF([Municipality]="Jeffersonville Village",17,IIF([Municipality]="Liberty Village",18,IIF([Municipality]="Monticello Village",19, IIF([Municipality]="Woodridge Village",20,IIF([Municipality]="Wurtsboro Village",21,<Null>)))))))))))))))))))))
This, obviously, is too long but the chunks don't work either. I need to accomplish the following process.
- Select a domain description value from a drop down list (this part works fine as it is a manual process, not utilizing the dynamic value table.) Codes are a two letter value for the town, 3-6 letter value for the villages. Descriptions are as shown above in the IIF statement I was hoping to use. I tried using the code, as opposed to the description, in the IIF expression and that does not work either.
- Based on the selected value in the Municipality field the MunicipalID field should autopopulate with a corresponding number (as shown above in the expression).
I have tried, for the false result, a number of options including 0, Null, <Null>, 00, "", and not putting anything in that result. Nothing.
I set the "On Change Attribute" to TRUE, all others to FALSE, as that is the most appropriate for what I am trying to accomplish. When that didn't work I tried it with TRUE for the standard three and FALSE# for "On Manual" but that does not work either.
Any suggestions/help is greatly appreciated. I'm still fairly new at using the attribute assistant.
Jenn
