Using the samples I can utilize a FeatureLayer but haven't been able to figure out how to load a mobile map package. Any suggestions?
Thanks
I see what you are asking. It is a static method so it would be something more like this:
_mappackage = await MobileMapPackage.OpenAsync("D:\\Source code\\Data\\Test.mmpk");
_mappackage = await OpenAsync("D:\\Source code\\Data\\Test.mmpk"); var mapPackageUri = new Uri(_mappackage.Item.Url); var mapTable = new ServiceFeatureTable(mapPackageUri); var mapPackageFeatureLayer = new FeatureLayer(mapTable); myMap.OperationalLayers.Add(mapPackageFeatureLayer);
More specifically I'm not sure what to do for the OpenAsync method.
I don't understand your question. What do you mean you are not sure what to do?
This MSDN documentation may help better explain how await works:
await (C# Reference)
I'll dig into that a bit more because I'm sure this stems from my lack of experience in c# and Xamarin. In my bit of code above I get the error that OpenAsync does not exist in the current context. I'm not sure if I need to import something else or if I need to define OpenAsync myself.
I'm working off of the Xamarin.Forms api found at (MobileMapPackage.OpenAsync Method )
Signed in members can post, follow updates, and more. New here? Register a free account.
