How can make the results of LineOfSight into a buffer, not file?
2666
03-25-2016 08:25 PM
WentaoWANG1
Recently, I was trying to do a project about visibilityanalysis, which using LineOfSight. There is a very confusing place, LineOfSight directly save results into .shp file, and this has led to most of the running time is spent on writing files , how can I make the results of LineOfSight into a buffer, and then write to a file at once?
Tags (3)
WentaoWANG1
I found the solution:Using in-memory workspace.ArcGIS Help 10.1
WentaoWANG1
