Help removing part of text from a string for popup
1683
03-04-2024 08:05 AM
Laura
by MVP Regular Contributor
Here is an example of the links in my attribute table
Some start with R some with mceas01. Either way I want to keep whatever comes after "R:/" or "\\mcenas01\" using arcade in a popup. I tried calling support but claimed they could not help.
Laura
Update:
This ended up working for me
Mid ($feature.Hyperlink, 24)
Create an expression and then set up the hyperlink to be the website + this expression
VanessaSimps
You could do an if else statement- and then use the Right Function with a 3 for the R:/ and a 11 for the \\mcenas01\ ?
Laura
The right function says it gets values at the end of the link. This changes so it won't work for me
KenBuja
MVP Esteemed Contributor
You can use the Replace function to get rid of those strings, but you have to be careful. The Arcade interprets a backslash as part of an escape character, so you have to use it twice in Replace for it to work properly. This will replace either in a single line.
var output = Replace(Replace($feature.Hyperlink,'\\\\mcenas01\\',''),'R:\\','');
Laura
Update:
