Goemetric Network and integration with realtime database
1293
04-09-2017 11:29 PM
Bara_Dweikat
I'm working to integrate the gis geometric network with real time database by creating trigger in the Sql database to update the view table- the enable field of geometric network, and I'm succeed to see the values of enable field in the view table . The problem starts if I tried to do the set flow direction the arc map doesn't response and didn't view the flow arrows. Can any one know which table I have to update in order  the set flow direction work probably.
the attached photo :
1 : the point which read from the real time  database
2:  the enable field ( true , false ) read from the real time database
3 : the name of this field as in real time database
