arcMap addin tool issue: it closes the arcMap as we click the addin button
4290
6
12-17-2015 04:19 AM
TabraizAhmed
hello, how are you all
Can any body help me out with an issue raised with my arcmap tool, I have recently made a tool for arcmap its working good but the issue is the issue is that is some systems THE ARCMAP IS CLOSED as we click the button. i dont know what this issue is, somewhere its working ok but in some systems it's not.
Tags (1)
RebeccaStrauch__GISP
I'm assuming the various systems are using the same version/patches of ArcGIS ?
If it is working on some and not others, you may want to try Resetting your ArcGIS application profile​ on the machines that are not working to see if that fixes the issue.
FreddieGibson
Honored Contributor
Is this a Python addin or a .NET Addin?
TabraizAhmed
its a .net addin
KenBuja
MVP Esteemed Contributor
Does it close or does it crash?
TabraizAhmed
its close. it exits arcmap
KenBuja
Sometimes when there is an uncaught error, ArcMap will shut down. I would suggest adding in Try..Catch blocks in your code to see if there are errors occurring that cause a fatal failure.
