The Problem
Every GIS team has this experience: your ArcGIS Portal holds thousands of feature services, web maps, and hosted layers. Your colleagues need answers: "How many parcels are in this district?" "What layers are in this web map?" "Who last modified this service?", and the only way to get them is to open a browser, navigate to the portal, click through item details, and manually query layers.
Meanwhile, AI assistants like Claude, Cursor, and VS Code Copilot can answer complex questions in seconds, but they have no way to reach your portal data.
What if your AI assistant could query your portal directly?
What is MCP?
Model Context Protocol (MCP) is an open standard that lets AI assistants connect to external tools and data sources. Think of it as a universal adapter: the AI sends a request in a standard format, and the MCP server translates it into the right API calls for the target system.
There are MCP servers for GitHub, Slack, databases, and file systems. But until now, there was nothing production-grade for the ArcGIS ecosystem.
Introducing arcgis-portal-mcp
arcgis-portal-mcp is an open-source MCP server that gives AI assistants full access to ArcGIS Portal and ArcGIS Online. It provides 32 tools across three capability areas:
Read Operations (Phase 1)
- Search for items by keyword, type, or owner
- Inspect item metadata, tags, and descriptions
- List layers in a feature service with geometry types and feature counts
- Query features with attribute filters, spatial filters, and pagination
- List users and groups
- Check portal health and system status
Write Operations (Phase 2)
- Add, update, and delete features in hosted feature layers
- Update item properties (title, description, tags, sharing)
- Create groups and invite users
- Share or unshare items with specific audiences
Publishing & Admin (Phase 3)
- Upload files (CSV, Shapefile, GeoJSON) and publish as hosted feature services
- Create empty feature services with custom schemas
- Execute synchronous and asynchronous geoprocessing tasks
- View licenses, usage statistics, and portal system information
- Batch operations for bulk delete, share, and update
A Real-World Example
Here's what this looks like in practice. Once connected, you can have a conversation like this:
You: "Search for all feature services in our portal related to infrastructure"
AI Assistant: [calls search_content with item_type="Feature Service" and keyword "infrastructure"]
You: "How many features are in the water network layer?"
AI Assistant: [calls list_layers to identify the layer, then query_features with a count]
You: "Show me the 10 most recently modified parcels"
AI Assistant: [calls query_features with order_by="EditDate", limit=10, where="1=1"]
You: "Run the buffer analysis on the contaminated sites layer with a 200m distance"
AI Assistant: [calls execute_gp_task with the GP service URL and parameters]
No browser. No copy-pasting URLs. No manual query building.
Design Decisions
Two choices set this apart from a wrapper around the ArcGIS Python package:
1. Raw REST API, no ArcGIS package dependency
The server communicates directly with the ArcGIS REST API using requests. This means:
- No complex dependency chain to install
- Works reliably on Windows
- Full control over error handling and edge cases
2. Enterprise Portal + ArcGIS Online: same tools
The ArcGIS REST API is largely consistent across Enterprise Portal and ArcGIS Online. This server exploits that consistency: the same 32 tools work against both platforms with zero configuration changes.
For Enterprise Portal with 2FA, the client_credentials OAuth2 flow handles authentication without a browser. For ArcGIS Online or portals without 2FA, token-based auth is the fastest path.
Getting Started
# Install from GitHub
pip install git+https://github.com/Asem-D/arcgis-portal-mcp.git
Create a .env file in your working directory:
portal_url=https://gis.yourorg.com/portal
username=your-username
password=your-password
Add to your MCP client configuration (Claude Desktop, Cursor, etc.):
"mcpServers": {
"arcgis-portal": {
"command": "python",
"args": ["-m", "arcgis_portal_mcp.server"],
"cwd": "/path/to/arcgis-portal-mcp"
The server reads .env on startup and connects automatically. No manual connect_portal call needed.
What's Next
This is the foundation. The architecture is designed so that additional tools, deep admin operations, service management, and analytics can be added incrementally. The MCP standard is evolving, and as it does, this server can evolve with it.
The long-term vision: your ArcGIS Portal becomes an AI-queryable system, where any MCP-compatible assistant can interact with your spatial data through natural language.
Try It
The project is open-source under the MIT license:
I'd love to hear from the community:
- What's the first task you'd want your AI assistant to handle on your portal?
- Are there tools or workflows you'd like to see added?
- How are you currently using AI assistants with ArcGIS?
Feedback, feature requests, and contributions are welcome on the GitHub repository.
Disclaimer: This is an independent open-source project. It is not affiliated with, endorsed by, or sponsored by Esri Inc. "ArcGIS" is a registered trademark of Esri.
