Arcade root cube different results than Excel
1773
03-15-2024 07:19 PM
KeithWestberg
I have an equation in excel which is =130*(27^(1/3)) that returns 390. When i use this same formula in Playground and arcade via Pro, i get 3510.  I've tried every order of operation, but still cannot emulate the excel output.
The playground version is the following
return 130*(27^(1/3));
Any suggestions on why the difference would be greatly appreciated.  Thank you in advance.
KenBuja
MVP Esteemed Contributor
You have to use the Pow function.
return 130 * Pow(27, (1/3))
Tags (1)
KenBuja
Tags (1)
KeithWestberg
I had discovered that function but i was not using it correctly.  Thank you for the lightning fast response.  You rock!
