Append_management string equivalent for a boolean field
4171
08-10-2015 08:32 AM
AllanAxon
I am using a python script we already have to import data from Excel to a geodatabase table. The field is now a boolean in the table and I'm using: listed \"listed\" true true false 50 Text 0 0 ,First,#,c:\\temp\\agol.csv,listed,-1,-1;
The error I get is: "ExecuteError: ERROR 001156: Failed on input OID -1, could not write value 'False' to output field listed
I think I need to change my field mapping to: listed \"listed\" true true false 50 Boolean 0 0 ,First,#,c:\\temp\\agol.csv,listed,-1,-1; but that still gives the same error. What are the valid field types that go in this position of a field mapping string?
Allan
DarrenWiens2
Is the data type of your field truly "Boolean" or perhaps a 1-digit integer or a text field? I don't see Boolean listed as a valid ArcGIS data type.
AllanAxon
My data type in SQLServer (destination) is bit, not null. In the Excel sheet (origin) it's either "TRUE" or "FALSE"
AllanAxon
The field type in SQLServer is a bit field. I got by this problem by converting all the False values in the spreadsheet to 0 and the Trues to 1 and reading them as text. Will have to look at the design of the table for a long term fix.
