App, measurement widget & Coordinate systeme
2948
02-04-2016 05:14 AM
TimothéeColas
Bonjour,
Lorsque je configure le widget "mesures" de mon appli je peux choisir mon unité de surface, de longueur mais je ne peux pas choisir mon système de coordonnées, il est en WGS84 et n'est pas modifiable. Donc lorsque j'utilise l'outil "emplacement" dans le widget "mesures",  mes coordonnées sont dans ce système.
Est-il possible d'une manière où d'une autre de modifier cette option ? je souhaiterais pouvoir mettre cet outil en Lambert 93.
Merci d'avance
*Hello,
When I configure the measurement widget  I can choose my unit area, length, but I can not choose my coordinate system, it is in WGS84 and is not editable. So when I use the location tool in the measurement widget, coordinates are in this system.
Is it possible to change this option? I wish I could put this tool in Lambert 93.
thank you beforehand*
AdrianWelsh
MVP Honored Contributor
I would imagine that since all of the web basemaps are in the WGS84 Web Mercator system that you will not be able to change to the Lambert system without completely customizing this map through custom development. I would think that you would need to have the basement in this Lambert system first and then put your data on top of it.
Though, I am curious to hear what others have to say.
TimothéeColas
Weird... because you can custom coordinate system of coordinate widget near scale bar.
But this coordinate widget can't give live coordinate counter to measurement widget.
AdrianWelsh
I don't really know. Any other ideas from folks on this board?
