Arcade function to get symbology color of the layer/ feature service based on unique values
687
05-31-2024 12:29 PM
Status: Open
GISCC
When configuring  a custom pop-up or labeling and a feature layer has different color based on the unique values of a particular field. Would like to have an arcade function to grab the color. Instead of finding the Hex# or rgb of the symbol color for each unique values. If you have a lot of unique values, it is tedious to go through and find the color values. If the end user doesn't like the color for some reason then you would need to change the code to reflect the change of the unique value color.
Tags (1)
