"failed to perform histogram color balancing"
1922
6
03-25-2019 08:00 AM
Jamina_Fritts
Hello, I am currently using Arcmap version 10.4.1 and am having a problem with color correction.  Under the color correction tab, when I select histogram balancing I receive the following error:  "failed to perform histogram color balancing".  I am wondering if this is a known error of this version of ArcMap and if so, is there a patch or update that corrects it?  Thanks!
Robert_LeClair
Esri Esteemed Contributor
Are you trying to do this on a mosaic dataset?  Please advise.
Jamina_Fritts
Yes, I added it to a raster catalog that I created.
Robert_LeClair
Okay, you added it to a raster catalog NOT a mosaic dataset?  The reason I ask is there is information about this if it's in a mosaic dataset so I wanted to confirm. MDS and RC are two different beasts.
Jamina_Fritts
Yes on the raster catalog .
Robert_LeClair
Okay - great!  There's a Tech Article about this issue with Mosaic Datasets but I wonder if it's the same issue with Raster Catalogs.  Worth a shot to investigate.
Jamina_Fritts
Thanks for the article.  I did verify that both sets of my data have three bands.  I'll do some more research online .
