Hello all,
I am seeking assistance with developing a ArcGIS Online pipeline. I am attempting to 'populate' data from a point feature layer into a polygon feature layer.
I have 2 feature layers: 1) A polygon feature layer that came from a deployed ESRI solution (CPC Projects in feature layer screenshot below). 2) A point feature layer that is tethered to an API which auto-updates with new information daily (Projects feature layer in screenshot below).
We are attempting to connect the ESRI solution polygon layer with the point feature layer in a way that does not create a new feature layer. We would like to develop a Pipeline that populates the point feature layer data into specific matched fields of the polygon feature layer based on a spatial join.
I am unfamiliar with the best order-of-operations for this in a Pipeline. I have been testing out the 'Map fields', 'Update fieds', and 'Join' tool in a test pipeline, but cannot determine the best flow for running the tools? Additionally, because I do not want a new feature layer output, the 'Add and Update' function on the output feature layer tool would need to be used, but because fields need to be matched from the target-polygon layer and the joining-point layer, I'm also uncertain when the 'Map fields' tool would need to be performed?
Below is a screen shot of my preliminary explorations. Hoping someone has an idea on the best order of operations for executing this.
