Which ArcGIS app to use that allows the ability to query, filter, and export data from field work done using ArcGIS 123SurveyConnect
770
06-23-2022 03:29 PM
AdrianRamos80
My name is Adrian Ramos. I am in need of help. I want to know which apps or app is best for allowing me to query, filter, and export data done from field work done using ArcGIS 123SurveyConnect?  Preferably can do this on a map. Also cannot be Dashboards.
Thank you,
Adrian Ramos
ChristopherCounsell
MVP Frequent Contributor
The Survey123 website is a great default option. It's designed to work with your survey and will let you do all the things you have requested.
https://doc.arcgis.com/en/survey123/reference/whatissurvey123.htm
Otherwise, you can work with the hosted feature layer (views) directly by adding them to a web map and then building apps on top of them. Again, two default great options are the Experience Builder or Web AppBuilder as they will let you add desired functionality.
