What is the best way to rename a field in an Oracle 11 SDE geodatabase
876
08-08-2012 04:36 AM
JoseSanchez
Hi all
JakeSkinner
Esri Esteemed Contributor
Hi Jose,
If you are using ArcGIS/ArcSDE 10, create a new field with your desired field name and then calculate the old field to the new field using the field calculator.
At 10.1, you can rename the field in ArcCatalog > feature class Properties > Fields tab.  See more information under 'Renaming Fields' here.
