What is the best way to do a mass field calculate on branch versioned data?
526
12-05-2025 06:04 AM
MDB_GIS
I added a new field to a dataset and needed to field calculate about 20k features. I started the calculation about 30 minutes ago and it is still going. Any way to speed this up?
SeyiO
by Esri Contributor
Hello @MDB_GIS
Here are a couple of things I would suggest
  • Run the calculation via the feature service, not the database.
  • Try to close the attribute table and disable layer drawing during this operation. Leaving these options running contribute can to the performance issue
  • Check your internet connection for any network latency. (VPN etc.)
  • If the service has validation rules and attribute rules each update triggers extra checks. You can temporarily disable the rules (if allowed) for bulk updates
  • You can also consider running the operation in chunks (e.g. 5000 at a time) or using python.
Seyi Ogundeji
Technical Support Analyst- Data Management
