WGS_1984_UTM_Zone_17S to UTM Zone 17, Southern Hemisphere - Raster file
1071
10-18-2012 03:19 PM
PaolaPaez
I have a raster file in WGS_1984_UTM_Zone_17S, and i need transform the raster file to UTM Zone 17, Southern Hemisphere. I use the tool project raster, but, after of the process, the coordinate system of the output file es the same than the input.
What is wrong?
Thank you, for the help.
Regards.
DevendraDahal
You are not clear what really you want to change. The input and output projections seem same. do you want to change WGS to something else? please clarify than it will be easy to give an answer
MelitaKennedy
Esri Notable Contributor
This may be what you're confused about...
When part of a UTM-related coordinate system name, 'S' means South and 'N' means North for the Southern and Northern hemisphere zones. If given a UTM string or notation like 17S 432938 3868920, the 'S' could mean a latitude band. That is, the data falls between 32N and 40N.
Melita
