underlying dbms error ora-00001 unique constraint violated
6315
07-30-2013 11:10 PM
hananelyan
Dear All
Please help me with my new problem in ArcSDE geodatabase ,
I have layer name it landuse when i unregisterd layer the message appear
underlying dbms error ora-00001 unique constraint (GAM.A6_D910) violated  GAM.LANDUSE
I did the post and reconcile to all my data base and then compress it  , the post and reconcile succsefully and the compress succesfully but when i check unregisterd as vesion for landuse layer the messgae appear
thank you
AsrujitSengupta
Hanan,
I would suggest creating a full backup of your geodatabase and then running the "sdegdbrepair -o diagnose_tables" to look for any orphaned records.
If any orphaned records are found, you can run "sdegdbrepair -o repair_tables" to correct those records.
Hope this helps!
Regards,
hananelyan
Dear All
The previous problem was solved.
But now when I work post and reconcile , and then I work compress , compress  has been successfully but virtually no compress because when I inquired at the Oracle gives no records, no compress that has been done successfully, knowing that I killed all users .
thenk you
RedaAli
Hi Hanan ,
Would you mind inform us,
How did you solve the first problem?
Reda Ali
AsrujitSengupta
As suggested in the second post of this thread, run the sdegdbrepair utilities and let us know if that helps!
