Unable to save edits : the row supplied is not the row expected
2865
03-11-2018 08:04 AM
PravinMore
Some of our editors started receiving error while saving edits in ArcMap. (Image attached) along with this error they receive error unable to save edits while flushing edits to the database (Image attached). Following is our editing  environment.
Windows 10 - 64 bit
ArcMap : 10.4.1
Enterprise GeoDatabase : 10.4.1
ORACLE Database 12c (12.1.0.1.0)  - Exadata Server
Tags (1)
Asrujit_SenGupta
TinaMorgan1
Have you ran Verify Connectivity or Repair Connectivity,  on your network?  You may also run Verify Feature Network Geometry to check for issues with the network geometry.
About Verify Network tools and commands—Help | ArcGIS Desktop
PravinMore
We are facing same issue again and we ran Verify Connectivity or Repair Connectivity and Verify Feature Network Geometry but issue is not resolved.
Also one particular dataset gets disconnected in ArcMap and then we run repair versions tool.  Repair version tool log contains lines for  2 rows added and 5 rows delated in aaa_N_props table.
PravinMore
Repair Version log having attached Add and delete rows info.
