Trying to Create a 10.0 geodatabase in 10.2
694
6
03-14-2014 07:31 AM
JessicaSchneider
I am trying to create a 10.0 gdb in a 10.2 environment.  I have found the tool to do this in toolbox and it finishes but when I look at the properties in catalog it says this Geodatabase matches the ArcGIS release you are currently using.
Anyone else have this issue?
Is it teasing me or did it really not work?
RobertBorchert
Honored Contributor
Your better off finding a 10.0 database, cleaning it out and simply  filling it from your 10.2 database.
ShawnThorne
You will need to install ArcSDE 10.0 and execute the 'sdesetup -o install ...' command to create a 10.0 Geodatabase in your RDBMS.
Since you've already created a Geodatabase using ArcGIS Desktop 10.2, there is no way to downgrade it to 10.0.  The only alternative is to delete & recreate the SDE user, before running the command above.
Refer to the 10.0 Help for more information on using this command.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/  >  Search for : sdesetup
Hope this helps.
-Shawn
WilliamCraft
MVP Regular Contributor
That is strange.  Are you creating a file or personal geodatabase using this method?  Try re-starting ArcGIS Desktop once the geodatabase is created; then re-check the properties.
RandyKreuziger
Jessica,
  What type of database are you looking for?  If it's a personal or file geodatabase check out James Fee's website.  He has saved empty versions.
http://www.spatiallyadjusted.com/2006/11/21/esri-92-personal-geodatabases-in-arcgis-91/
VinceAngelo
Esri Esteemed Contributor
The File Geodatabase format hasn't changed, so 10.0/10.1/10.2 FGDBs will all be
current in the eyes of 10.2 Desktop.
Database servers (Express) and Enterprise Geodatabases differ by release.
- V
AsrujitSengupta
Its just teasing you! 🙂
