Trouble with Geotagged photos to points tool
5825
5
01-29-2014 09:54 AM
PaulHuffman
I'm trying to help a guy with photos from his Nikon Coolpix P6000 that are supposedly geotagged.  I told him at first I'd just run them through the GeotaggedPhotosToPoints tool in Arc Desktop 10.2, but each time I try this I can only get the very unhelpful Error 999999 and "Failed to execute"
I set up the tool to take all the files from his directory and put the output FC into a new 10.2 file geodatabase.
Examining the directory I was given, each phot has a jpg, a aux.xml file that seems to contain just some metadata parameters, and an .ovr that seems to be a pyramid file.  I don't see where the coordinates are stored.  I wonder if he hasn't set up his camera correctly to geotag his photos, or is this format not recognized by Arc Desktop.
Update:  Nikon has a photo viewing utility ViewNX2 that shows the coordinates and a map with photo locations for almost all these photos.  I just don't see where these coordinates are stored, and apparently, neither does GeotaggedPhotosToPoints.
Update 2: The Coolpix P6000 pdf manual says files are "DCF, Exif2.2, and DPOF compliant" (p.211) EXIF is supposed to be the format The ArcMap tool is looking for.
LucasDanzinger
Esri Frequent Contributor
You might try running a few of them through an online exif metadata viewer to see if you can find any information about location. Here's one I just tried with some pictures I took on my phone - http://exif-viewer.com/
Edit - sorry, missed your first update where the Nikon photo Viewer showed your pictures. Maybe you could upload an image or two, along with the associated files in a zip file?
PaulHuffman
LucasDanzinger
Interesting, pointing to a folder that contains one of the images works for me. I tried on a machine with 10.1 and 10.2. I attached the tool dialog from my run. All I specified was the input folder and accepted the defaults for the other parameters. If you try the same with the one image, does it work?
PaulHuffman
Hey, what do you know?  I put 10.2.1 on this PC, and the Geotagged photos to points tool just ran through all the photos in the directory without error.  I don't know what was going on before.
I wonder how I might hand this new photo point FC back to the guy so that the paths in the Path item will be correct, maybe relative rather than absolute paths?
Update: I don't have to correct the paths. If you check the box "Add Photos as Attachments" adds the photos to the geodatabase as blob items and relates them to the points. I should read the tool help more often. However, I will have to dumb down the geodatabase back a couple revs so the guy can read use it.
Update 2: Hey, it turns out this was a somewhat known bug in 10.2, perhaps triggered in my case by a non-georeferenced photo in the directory: http://forums.arcgis.com/threads/92246-GeoTagged-Photos-To-Points-ERROR-999999-Error-executing-funct...
AntonioLop
Lately I´m using ARCGIS 10.2 with a WIN 7 PC.
Yesterday update to ARCGIS 10.2.1, i play Geotagged-photos-to-points-tool and i recive the error 999999.
Usually i´m working with WIN7...but today I probe a PC with XP and ARCGIS 10.2.1 installed.
¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡THE GEOTAGGED PHOTOS TO POINTS TOOL¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡ WORK FINE..........exporting it to shapefile or GEodatabase.......GREATTTTT
I belive that the problem is when we run arcgis 10.2.1 under WIN 7......I BELIVE is a non find BUG.......TIME To TIME
P.D.---in WIN XP, I´m using the tool with a folder with 250 photos and with non geotagged photos and WORK FINE...IN WIN 7:mad:
