Topology - "Line must snap to edge of polygon"?
3857
12-01-2014 10:31 AM
denisedavis
I'm trying to get the vertex at the end of a line to snap to the closest polygon edge. Is there a tool or topology rule that can help me do this? I have thousands of lines that need to be snapped so if there is a simple way to do it, I'd sure like to find it. Snapping each one of these lines is going to be so much work, it would almost be easier to re-digitize them all.
Thanks for any help!
DarrenWiens2
MVP Alum
If you have Standard or Advanced licensing, use Snap. Make a copy first, because this changes the input data (no backsies).
SepheFox
Hi Denise, Try using the Snap tool: ArcGIS Help 10.1
