The fields of the attribute table of the raster in the ccatalog window
1301
05-25-2012 09:58 AM
JamalNUMAN
Legendary Contributor
The fields of the attribute table of the raster in the catalog window
I�??m wondering why the �??catalog view�?� of doesn�??t show the fields of the attribute table of raster as main component of its properties while it does so for polygons, polyline and points?
[ATTACH=CONFIG]14652[/ATTACH], [ATTACH=CONFIG]14653[/ATTACH]
Thank you for the help,
Best
Jamal
Jamal Numan
EricRice
Jamal,
You can't have a feature class of point, line, or polygon without also having an attribute table.  "Fields" is something that is common to all of those and thus they have a shared UI.  Raster data on the other hand, does not always have a table.  Multiband imagery doesn't support tables, nor does 32 bit float.  Integer data can support a table, but depending on the data it may be built automatically or it could be up to you to run the Build Raster Attribute Table tool to force a table to be built.  Because of the lack of uniformity among the various types of raster data with respect to attribute tables, they do not have a shared "Fields" tab in the properties dialog.
Regards,
Eric
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Jamal,
Regards,
Eric
I appreciate your continuous help Erc.
I tried to create a table for the �??rainfallvolume�?� raster but sounds not to work.
What might be the reason in this case?
[ATTACH=CONFIG]14733[/ATTACH]
EricRice
That raster is floating point.  You must have an integer raster to build attribute tables.
Eric
