Standardizing Addresses in 10--Won't ignore data after # or comma anymore??
1207
11-08-2010 02:21 PM
ChristyJacobs
In 9.3 when you standardized addresses AG ignored any data in an address after a # or a comma, which was usually a unit or apt. number not needed to geocode.  This isn't the case in 10. Is there another character to use or a script I have to apply for this.
I am using an in-house parsed address locator so maybe that's the problem? It worked in 9.3 fine.
PrasannaGovindan
Open the USAddress.lot style and change the
"<prop name="StoreStandardizedRefData">True</prop>"
Then recreate the locator. This should solve the problem.
Prasanna Govindan
Geocoding team
ESRI Redlands, CA.
ChristyJacobs
Thanks for the suggestion but I think I wasn't clear the first time. The error is in the "Standardize Address" tool under Geocoding Tools. If an address has a # sign in the address field, it just ignores and leaves blank for the house number and street name. All other lines are OK. I have been using the Single House locator to try and standardize my address table.
