shapes of this entity type is not allowed in this layer [shape]
1030
01-18-2012 09:05 PM
baohuachu3
Hi All,
   I have problem when move,add vertex, delete vertex on polyline.
The exception message is "Move Error, shapes of this entity type is not allowed in this layer [shape]"
see screenshot: [ATTACH=CONFIG]11288[/ATTACH]"
Environment:
      ArcGIS desktop 10 with sp3;
     Sqlserver 2005;
     ArcSDE 10;
Features:
           regsitered as versioned;
           in geometric network;
JakeSkinner
Esri Esteemed Contributor
Does your geometric network contain both Z-enabled and non Z-enabled feature classes?  If so, you are most likely encountering a bug:
NIM068617 Editing ArcSDE geometric networks that involve a mix of Z-Enabled and Non Z-Enabled feature classes results in the the following errors: "Modify Feature: An unexpected failure occurred. Shapes of this entity type not allowed in this layer [SHAPE]"
The workaround is to create a geometric network in an ArcSDE feature dataset that contains all Z-enabled feature classes or all non Z-enabled feature classes.
baohuachu3
All feature classes participate in network their "coordinates include Z values" options are checked.
If the geometric network is removed there will is no this problem. In personal GDB there is no this problem.
So this happens in ArcSDE GDB with geometric network. At the beginning this problem not appear.
Is there any solution to this?
baohuachu3
Attached is the xml work workspace document.  Is there any ESRI guy to help me  to analyze this problem.
When move line objects there will exception pop up as beneath. It says "move , cause exception, shapes of the entity type not allowed in this layer"
[ATTACH=CONFIG]11513[/ATTACH]
It will happen in :
     ArcGIS desktop 10 sp3;
     ArcSDE 10 sp3;
     SqlServer 2005;
