Readers,
good afternoon. I was assigned a task to 'fix' problems with missing record counts from previous year reports. Last time a nationwide report of land use report was run during Oct 2019-Jan 2020 time frame and all was good. Similarly Oct 2018-Jan 2019 records were intact.
Only thing that changed if it should affect - In August of 2020, many servers were upgraded from ArcGIS 10.5.1 to 10.7.1 (dev stack and prod stack - separately).
Oct/November 2020, when the same programs were run, the record counts were at 40% of expected values.
Here are the facts:
- SQL Server (w shape geometry) national table has 21.1 million records - as expected.
- We split it state wise using STIntersect() function and got many tables that added up 21.1 million records.
- When we wanted to deliver those many tables to the customers as file geodb, we did an export from Arc Catolog-->Right Click--> Export --> To Geodatabase (single) and To Geodatabase (multiple) and we lost many records. No difference whether we used the single or double option
- We did a shape.STIsValid() = 0 to see which records were failing - no records seemed to be invalid in SQL server.
- We use ArcGIS Pro and Arc Catalog to export and we found that there was no difference in the missing record counts (exploring 32 bit vs. 64 bit issues - but does not seem to be so).
Please see the attached spreadsheet that talks about the differences.
Thank you for your support.
regards
ravi kaushika
