Renaming the raster doesn�??t work.
1460
05-25-2012 10:04 AM
JamalNUMAN
Legendary Contributor
I wanted to rename the raster �??rainfall�?� to be �??Rainfall�?� (to make the first letter capital) but the raster doesn�??t respond! It remains as �??rainfall�?�!
What might be the problem?
[ATTACH=CONFIG]14654[/ATTACH]
the raster is attached.
Thank you for the help,
Best
Jamal
Jamal Numan
DanPatterson_Retired
remove it, rename it, re-add it
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Thank you for the answer.
What do you mean by �??remove it�?�! I�??m working already on the catalogue view!
[ATTACH=CONFIG]14660[/ATTACH]
Best
Jamal
Then you will have to refresh ArcCatalogue (which I never use), within arcmap, the TOC generally doesn't get refreshed, where I was assuming you were working from.
