Is there any way to rebuild an address locator without being the owner? On the ArcGIS help 10.2, here, it only says you need write privileges.
The end goal is a python script to rebuild the address locator at some regular interval. To test it, however, I need to be able to run the rebuild tool in the first place.
I should note that the address locator is in an sde database currently; I'm not sure if that has anything to do with it.
