I am looking for support on Publishing Data Interoperability tools and consuming those as REST/SOAP services. Can any one know Enterprise level implementation on server side please share help resources.
Did you check the steps in Publishing Data Interoperability tools with ArcGIS Server?
Dear Jayanta thank you for reference, I gone through the help resource and its helped me a lot. After that I tried to consume as REST but it is failing. I rechecked Extinction on server side also , its authorized. while working with desktop its working fine after publishing in to the server it failing.. what could be the reason I am unable to figure out.
What error are you getting when you run the GP service?
while using "parameters are not valid" error is coming. I am thinking that input parameter file format or else arcgis server version comparability. Server with 10.4 and my desktop 10.3 is this will be a issue?
Signed in members can post, follow updates, and more. New here? Register a free account.
