polygons duplicates
1861
05-05-2012 02:47 AM
hazemhafez
Hi all, i would like to detect polygons duplicates( tow or three polygons above others) in one polygon layer. How can i do that ? What tool do I need to use ?
because this polygon imported from autocad format and have some errors in it , so i want to delete this errors (duplicates)
Thanks very much
DanLee
by Esri Regular Contributor
hazemhafez
Hello all,
Sorry,my Question about how to find polygons duplicates( tow or three polygons above others) in one polygon layer.
hazem
DanLee
Have a look of the tools I mentioned to you. They process features in the same feature class, i.e. polygons in the same input file.
AntonioLocandro1
You could create a geodatabase, import the polygons to a feature class then create topology for it.
