Polygon does not close properly error in default version of feature class
3652
12-20-2013 06:29 AM
EdwardGlover
The shapes below all show up with an error using the sdelayer command.  The verification code for each of those objects is 150. That code translates to �??SE_INVALID_POLYGON_CLOSURE�?�, the polygon does not close properly.
How do I correct this error (i.e. geometry) when the feature class does not have a topology?  I cannot create topology because it does not reside in a feature dataset.
http://edndoc.esri.com/arcsde/9.0/capi_functions/returncodes_incl.htm
ArcSDE 10.1  for Oracle11g Build 679 Thu Apr  5 11:43:21  2012
Layer      Administration Utility
Row Id,FID,Entity Type,Annotation,Cad Data,Number of Points,Number of Parts,Number of Subparts,Self-Touching Rings,Minimum Precision,Verification
12645,12645,A,F,F,17,0,0,F,High,-150
2413,2413,A,F,F,10,0,0,F,High,-150
2418,2418,A,F,F,25,0,0,F,High,-150
2515,2515,A,F,F,18,0,0,F,High,-150
2516,2516,A,F,F,8,0,0,F,High,-150
2671,2671,A,F,F,13,0,0,F,High,-150
2680,2680,A,F,F,17,0,0,F,High,-150
2681,2681,A,F,F,20,0,0,F,High,-150
339,339,A,F,F,20,0,0,F,High,-150
340,340,A,F,F,32,0,0,F,High,-150
IvanGnevanov
Edward,
I've had an experience of accessing the MapInfo data stored in Oracle Spatial format. There were a lot of geometry errors.
If you have a similar situation, you can check and correct the geometry using MapInfo.
What is the source of your data?
Ivan
