Performace of Mosaic Dataset when launched as image service
984
11-30-2012 05:00 AM
VikramS
All,
I would like to know which one of the below would give a good performance for Image Service
Mosaic Datasets with Overviews and Pyramids
OR
Mosaic Datasets with Overviews Alone
The Source Raster can be .sid,jpeg ,tiff formats
Thanks
JeffreySwain
Very open ended question.  It is usually data specific.  Usually if you ignore the pyramids, it will generate more overviews to cover for the data.  The overviews increase the performance.
VikramS
We already have pyramids for some of the source data . So my question if we remove the pyramids and rebuild overview . Is this going to improve the performance ?
JeffreySwain
The presence of the pyramids will affect how many overviews are created.  If you remove the pyramids and then generate new overviews you are not really gaining much. I am not sure where you are going with this, but perhaps if you are looking to generate more overviews, you can use the define overviews to force more overviews to be created. This will give the image service more levels to choose from and increase performance. Perhaps you should take a look at this blog.
EricRice
Greetings,
I strongly encourage you to read this two part blog discussing pyramids/overviews.
Overviews and pyramids: Part 1 of 2, What are they and why do I need them?
Overviews and pyramids: Part 2 of 2, Doesn�??t my mosaic dataset use both?
Best,
Eric
VikramS
Thank you jeff and Eric for the reply .. The Blog was really good . It gave useful tips . Probably to make myself clear I am restating my problem ..
We Have Satellite images , elevation data in different file formats .. Previously While we created the mosaic datasets we built overview (Build Overviews) as well as the pyramids (Build pyramids and statistics tool) .. Now we are cleaning the mosaic datasets so this question came up whether
Both pyramids and overviews are required for good performance of mosaic dataset
OR
Only Overviews are enough for good performance of mosaic dataset
