Hi, I wouldn't expect to see those values unless the feature dataset/class was empty or somehow data was getting placed at that location.Melita
After investigating the "Parcels" feature class it seems that somehow there are records (3 total) with AREA and LENGTH of 0. I'm not sure if this is by design with the Parcel Fabric or not? I assume this is what is causing the extents to go all the way to the extremes. Any info on the SRID 0 issue?
Another question: you�??ve noted in your post that the General tab states �??Storage: High Precision using Geometry spatial type (SRID 0)�?�To confirm what you're seeing on that General property page: it does not state �??�?�using ST_Geometry spatial type�?��?� ? In other words this particular reported property has two problems; first is that the SRID is reported as 0, and the second is that it is not reporting the �??ST geometry�?�?Thanks,-Tim (Parcel Editor team)
