Multiple Hyperlink Paths
1688
09-27-2016 12:28 PM
LauraGiboo
We have Arc users who are disconnected from the network all day and others are connected to the network all day. Basically, I want a way to build a smart hyperlink tool that when clicked with look in multiple locations for the hyperlink source.
The feature class has a text field called "DWG" that has the document name in it (i.e. UC-D-0145.pdf).  This field will be used for the hyperlink tool.
1. Look to our SharePoint Site (if not there), then:
2. Look at our network L drive (if not there), then:
3. Look at the local computer drive C.
All three of these locations are set up the same:
<sharepoint website>/ts/gt/DwgsMisc/<document name>
L:\TS\GT\DwgsMisc\<document name>
C:\TS\GT\DwgsMisc\<document name>
Any ideas on how to accomplish the task above?
Thanks in advance!!
DanPatterson_Retired
so something like the code sample that you can use in field based hyperlinks?
Using Hyperlinks—Help | ArcGIS for Desktop
you would have to write your own code though... python has try-except blocks that when used with a time test, might work
