Minimum boundary geometry
1120
02-17-2022 01:40 PM
Labels (2)
DylanGust
How do I get the Minimum Boundary Geometry tool to accurately create a polygon based on a certain column in the attribute table?  Also, is it possible to create a polygon based on both a data within a certain column and a given distance away from the point data?
Thank you for the help.
DanPatterson
minimum bounding geometry uses geometry, not attributes.  You can query for the attributes you want, then save to a new featureclass to limit the geometry you want.
If you have point data and you want a certain distance away from the bounding geometry, determine it first, then buffer the result
... sort of retired...
