migrate sde_binary to st_geometry
2761
10-18-2012 01:45 AM
GISGroup
I have installed arcsde 10 with oracle 11g and default storage configuration is ST_GEOMETRY.  I imported my existing arcsde 9.3 database with default storage configuration as sde_binary.
I am able to import all the layers using oracle dmp files. I also successfully upgraded database.
But when I try migrate existing layer storage type from sde_binary to st_geometry, I got error as it is not supported on a view. I tried using gptool and arcsde command line and I got the same result.
Please provide me solution.
Regards
Kumar
VinceAngelo
Esri Esteemed Contributor
Are the tables in question spatial views? If so, the error message is accurate, and you'd need to
drop the view ('sdetable -o delete -t view_name'), then recreate the view (preferably with SQL, then
by using 'sdelayer -o register'). Be sure to convert the base layer table first.
-V
